Saltar al contenido principal
Zeki Droid Tablet Back Casing Replacement
Qué necesitas
  1. Zeki Droid Tablet Back Casing Replacement, Back Casing: paso 1, imagen 1 de 1
    • Remove the back casing by slowly popping each tab out with a plastic opening tool.
  2. Zeki Droid Tablet Back Casing Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Remove the tapes one by one from the connecting wires with tweezers.
  3. Zeki Droid Tablet Back Casing Replacement: paso 3, imagen 1 de 1
    • Remove the black clips from both sides of the casing with a plastic opening tool.
    • The clips should pop off separate from the speakers.
  4. Zeki Droid Tablet Back Casing Replacement: paso 4, imagen 1 de 1
    • Remove the speakers from the back casing.
    • Do not tug on the speakers because they are connected to fragile wires.
  5. Zeki Droid Tablet Back Casing Replacement: paso 5, imagen 1 de 1
    • Pull the speakers away from the back casing carefullly.
Conclusión
Wyatt Nelson
Miembro Desde 03/11/15
120 Reputación
1 Guía escrita
Equipo
Colorado Springs, Team 2-6, Panko Spring 2015 Miembro de Colorado Springs, Team 2-6, Panko Spring 2015
UCCS-PANKO-S15S2G6
Miembros de 3
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 717
