Saltar al contenido principal
Zeepad 7DRK Speaker Replacement
Qué necesitas
  1. Zeepad 7DRK Speaker Replacement, Speaker: paso 1, imagen 1 de 2 Zeepad 7DRK Speaker Replacement, Speaker: paso 1, imagen 2 de 2
    • Begin by popping off the plastic yellow device casing with the soft tip prying tool.
    • Start by using the wedging the tip of the tool in and working your way around the device to make things easier.
  2. Zeepad 7DRK Speaker Replacement: paso 2, imagen 1 de 2 Zeepad 7DRK Speaker Replacement: paso 2, imagen 2 de 2
    • Once the device is opened, the speaker should fall out of its position.
    • Follow the red and black wires attached to the speaker to find the location of connection.
  3. Zeepad 7DRK Speaker Replacement: paso 3, imagen 1 de 1
    • The red and black wires are attached by a solder, in order to be replaced this connection must be broken.
    • Once the wires are disconnected, the speaker will be successfully removed and ready for replacement.
Conclusión
Alexandra Souza
Miembro Desde 10/20/16
222 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 6-8, Martin Fall 2016 Miembro de UMass Dartmouth, Team 6-8, Martin Fall 2016
UMASSD-MARTIN-F16S6G8
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 95
