Saltar al contenido principal
Zeepad 7DRK Power and Volume Button Replacement
Qué necesitas
  1. Zeepad 7DRK Power and Volume Button  Replacement, Power and Volume Buttons: paso 1, imagen 1 de 1
    • First find the power and volume buttons so that you are familiar with their location.
    • The smaller button is the power button and the larger button is the volume button.
  2. Zeepad 7DRK Power and Volume Button  Replacement: paso 2, imagen 1 de 2 Zeepad 7DRK Power and Volume Button  Replacement: paso 2, imagen 2 de 2
    • To open the tablet, use one of the soft-tip prying tools.
    • It is easiest to start by using the corner of the tool first and sliding the rest in. Then carefully move the tool around the edges of the tablet until it separates.
  3. Zeepad 7DRK Power and Volume Button  Replacement: paso 3, imagen 1 de 1
    • Be careful of how you open the tablet, as the button will want to fall out. Try opening it flat on its back to avoid this problem.
    • This is what the tablet looks like when pried apart.
  4. Zeepad 7DRK Power and Volume Button  Replacement: paso 4, imagen 1 de 2 Zeepad 7DRK Power and Volume Button  Replacement: paso 4, imagen 2 de 2
    • In the first picture you will see the power button. Notice the small plastic ring that sticks out the side, this is so the piece can be positioned easily when you put it back together.
    • In the second picture, the volume control button is shown. Again notice the small locator rings.
  5. Zeepad 7DRK Power and Volume Button  Replacement: paso 5, imagen 1 de 2 Zeepad 7DRK Power and Volume Button  Replacement: paso 5, imagen 2 de 2
    • Now remove the old or broken buttons, and replace them.
Conclusión
Una persona más ha completado esta guía.
Trevor Taylor
Miembro Desde 10/20/16
234 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 6-8, Martin Fall 2016 Miembro de UMass Dartmouth, Team 6-8, Martin Fall 2016
UMASSD-MARTIN-F16S6G8
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 346
