Saltar al contenido principal
Zeepad 7.0 Screen Replacement
Qué necesitas
  1. Zeepad 7.0 Screen Replacement, Screen: paso 1, imagen 1 de 2 Zeepad 7.0 Screen Replacement, Screen: paso 1, imagen 2 de 2
    • Power off the device and keep it unplugged.
    • Open the case using a plastic opening tool around the edges. Slightly pull the cover off.
    • Do not completely remove back casing because there is a speaker attached to the back.
  2. Zeepad 7.0 Screen Replacement: paso 2, imagen 1 de 1
    • Using the Phillips Head 0 bit, carefully unscrew the three 3.5mm screws holding the motherboard in place on to the back of the screen.
  3. Zeepad 7.0 Screen Replacement: paso 3, imagen 1 de 2 Zeepad 7.0 Screen Replacement: paso 3, imagen 2 de 2
    • Disconnect the two ribbon cables between the screen and the motherboard.
    • Be careful not to rip out the ribbon cables or you can harm the ports.
  4. Zeepad 7.0 Screen Replacement: paso 4, imagen 1 de 1
    • Cut the power cables connecting between the screen and the motherboard. There should be a red and black cable each.
  5. Zeepad 7.0 Screen Replacement: paso 5, imagen 1 de 2 Zeepad 7.0 Screen Replacement: paso 5, imagen 2 de 2
    • Separate the front screen protector from the lcd screen. There are clamps holding the screen in place.
  6. Zeepad 7.0 Screen Replacement: paso 6, imagen 1 de 3 Zeepad 7.0 Screen Replacement: paso 6, imagen 2 de 3 Zeepad 7.0 Screen Replacement: paso 6, imagen 3 de 3
    • Separate the LCD screen from the metal protecting case with the metal spudger.
  7. Zeepad 7.0 Screen Replacement: paso 7, imagen 1 de 3 Zeepad 7.0 Screen Replacement: paso 7, imagen 2 de 3 Zeepad 7.0 Screen Replacement: paso 7, imagen 3 de 3
    • After creating space to work, warm up a soldering iron.
    • Apply heat onto the solder over the corresponding cut wires to the new screen wires.
    • Cómo soldar y desoldar conexiones
    • The soldering iron will be extremely hot. Keep out of direct contact to other wires, the motherboard, and especially the battery.
    • Keep out of reach of children.
Conclusión
To reassemble your device, follow these instructions in order.
Una persona más ha completado esta guía.
Harry Winter
Miembro Desde 03/26/18
157 Reputación
1 Guía escrita
Equipo
IUPUI, Team S2-G1, Harley Spring 2018 Miembro de IUPUI, Team S2-G1, Harley Spring 2018
IUPUI-HARLEY-S18S2G1
3 Miembros
4 Guías creadas
2 comentarios
where do you buy the screen?
Zuzzi Z Amend - Contestar
i need a battery an a screen? is their a place on this page where to get them?
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 461
