Introducción
Sometimes bad things happen to good goggles. Use this guide to replace the camera assembly, which contains the lens, 8 megapixel sensor, keypad buttons, viewfinder, and battery. Whew!
Qué necesitas
Hold the iON in your hands with your thumbs on the clips next to the middle of the lens.
Pull the rubber housing apart to release the first two clips.
Remove the four 7.1 mm Phillips screws securing the camera housing to the goggle frame.
Casi Terminas!
Conclusión
