Saltar al contenido principal
ZTE ZMax Pro Rear-Facing Camera Replacement
Qué necesitas
  1. ZTE ZMax Pro Rear-Facing Camera Replacement, Back Panel Assembly: paso 1, imagen 1 de 1
    • Flip the phone over so that the back panel of the phone is facing up.
    • Wedge the plastic opening tool between the black outer panel and the silver side panel.
    • Push down on the plastic opening tool to separate the back panel from the rest of the phone.
    • Continue to do this around all sides of the phone until the back panel has popped all the way off.
    • Removing the back panel may make loud popping noises which is normal.
  2. ZTE ZMax Pro Rear-Facing Camera Replacement: paso 2, imagen 1 de 1
    • Using your fingers, slide the SIM card all the way out of the phone.
  3. ZTE ZMax Pro Rear-Facing Camera Replacement: paso 3, imagen 1 de 2 ZTE ZMax Pro Rear-Facing Camera Replacement: paso 3, imagen 2 de 2
    • Remove the yellow Kapton tape by using the tweezers to peel it up and away from the device.
  4. ZTE ZMax Pro Rear-Facing Camera Replacement: paso 4, imagen 1 de 1
    • Using the Phillips #00 screwdriver, remove the two 3.0 mm screws located near the top of the phone, next to the rear camera.
  5. ZTE ZMax Pro Rear-Facing Camera Replacement: paso 5, imagen 1 de 1
    • Remove the fingerprint sensor flex cable, using the plastic opening tool to lift it out.
  6. ZTE ZMax Pro Rear-Facing Camera Replacement: paso 6, imagen 1 de 2 ZTE ZMax Pro Rear-Facing Camera Replacement: paso 6, imagen 2 de 2
    • Using the tweezers, peel back the yellow Kapton tape located on the right side of the phone.
  7. ZTE ZMax Pro Rear-Facing Camera Replacement: paso 7, imagen 1 de 1
    • Using the Phillips #00 screwdriver, remove the 15, 3.0 mm rear panel screws located around the perimeter of the phone.
  8. ZTE ZMax Pro Rear-Facing Camera Replacement: paso 8, imagen 1 de 1
    • Flip the phone over so that the screen is facing up.
    • Wedge the plastic opening tool between the screen and the rear panel.
    • Push up on the opening tool to separate the panel from the phone.
    • Continue to do this around the entire phone until the rear panel is no longer connected to the device.
    • The rear case and screen are fastened tightly to each other. It might help to use the picks as wedges to keep the case and screen separated as you run the opening tool along the edges.
  9. ZTE ZMax Pro Rear-Facing Camera Replacement, Motherboard: paso 9, imagen 1 de 2 ZTE ZMax Pro Rear-Facing Camera Replacement, Motherboard: paso 9, imagen 2 de 2
    • Use the tweezers to peel off the yellow Kapton tape.
  10. ZTE ZMax Pro Rear-Facing Camera Replacement: paso 10, imagen 1 de 1
    • Use the plastic opening tool to remove the connectors on the motherboard.
  11. ZTE ZMax Pro Rear-Facing Camera Replacement: paso 11, imagen 1 de 1
    • Use tweezers to remove the antenna. The antenna comes up on the right side of the phone, by the battery, and is attached to the motherboard.
  12. ZTE ZMax Pro Rear-Facing Camera Replacement: paso 12, imagen 1 de 1
    • Using the #00 Phillips screwdriver, remove the 3.0 mm screw located on the right edge of the phone, above the battery.
  13. ZTE ZMax Pro Rear-Facing Camera Replacement: paso 13, imagen 1 de 1
    • Wedge the plastic opening tool underneath the motherboard which is located at the top of the phone.
    • Push down on the plastic opening tool, lifting the motherboard away from the phone.
    • Continue to do this around all sides of the motherboard until it is fully removed from the phone.
  14. ZTE ZMax Pro Rear-Facing Camera Replacement, Rear-Facing Camera: paso 14, imagen 1 de 1
    • Use the plastic opening tool to remove the rear-facing camera from the motherboard.
  15. ZTE ZMax Pro Rear-Facing Camera Replacement: paso 15, imagen 1 de 1
    • Using your fingers, pull the camera all the way off of the motherboard.
Conclusión
Una persona más ha completado esta guía.
Nicholas Leacox
Miembro Desde 04/18/18
1,721 Reputación
7 Guías creadas
Equipo
Cal Poly, Team S17-G3, Livingston Spring 2018 Miembro de Cal Poly, Team S17-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G3
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 213
