Introducción
This guide will show you how to replace the charging port. You will need a plastic opening tool, tweezers, and a Phillips #00 screwdriver.
Qué necesitas
Flip the phone over so that the back panel of the phone is facing up.
Wedge the plastic opening tool between the black outer panel and the silver side panel.
Push down on the plastic opening tool to separate the back panel from the rest of the phone.
Continue to do this around all sides of the phone until the back panel has popped all the way off.
Flip the phone over so that the screen is facing up.
Wedge the plastic opening tool between the screen and the rear panel.
Push up on the opening tool to separate the panel from the phone.
Continue to do this around the entire phone until the rear panel is no longer connected to the device.
Herramienta utilizada en este paso:Tweezers$4.99
Use tweezers to remove the antenna.
11 personas más completaron esta guía.
11Guía Comentarios
Very nice BUT where do you get the replacement charging port?
Where can I bye the parts
“Buy” as in purchase not “Bye” as in see you later.
How much is it cost to fix it
My charging port was 5.79 with free shipping at
James T. -
