Saltar al contenido principal
ZTE ZMAX Z970 Screen Replacement
Qué necesitas
  1. ZTE ZMAX Z970 Screen Replacement, Battery: paso 1, imagen 1 de 2 ZTE ZMAX Z970 Screen Replacement, Battery: paso 1, imagen 2 de 2
    • Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays.
    • Pull out the trays.
  2. ZTE ZMAX Z970 Screen Replacement: paso 2, imagen 1 de 2 ZTE ZMAX Z970 Screen Replacement: paso 2, imagen 2 de 2
    • Insert a plastic opening tool into the groove between the phone’s back cover and casing.
    • Move the plastic opening tool along the edges of the phone to unclip the two pieces.
  3. ZTE ZMAX Z970 Screen Replacement: paso 3, imagen 1 de 3 ZTE ZMAX Z970 Screen Replacement: paso 3, imagen 2 de 3 ZTE ZMAX Z970 Screen Replacement: paso 3, imagen 3 de 3
    • Remove the ten 1.2mm screws with a Phillips #000 screwdriver.
  4. ZTE ZMAX Z970 Screen Replacement: paso 4, imagen 1 de 2 ZTE ZMAX Z970 Screen Replacement: paso 4, imagen 2 de 2
    • Remove the mid frame with the plastic opening tool.
  5. ZTE ZMAX Z970 Screen Replacement: paso 5, imagen 1 de 2 ZTE ZMAX Z970 Screen Replacement: paso 5, imagen 2 de 2
    • Disconnect the battery from the motherboard.
  6. ZTE ZMAX Z970 Screen Replacement: paso 6, imagen 1 de 2 ZTE ZMAX Z970 Screen Replacement: paso 6, imagen 2 de 2
    • Wedge a spudger underneath the battery and gently pry upwards to remove the battery.
    • Once free from the glue, remove from device.
    • The glue holding down the battery is strong so work slow and cautiously to avoid starting a fire.
  7. ZTE ZMAX Z970 Screen Replacement, Screen: paso 7, imagen 1 de 1
    • Heat up the iOpener for 30 seconds and place on top of the phone for 2 minutes.
  8. ZTE ZMAX Z970 Screen Replacement: paso 8, imagen 1 de 1
    • Wedge the opening picks into all the corners of the phone and lift until the screen comes off.
Conclusión
Ismail Jhaveri
Miembro Desde 02/15/18
159 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S17-G3, Boczar Spring 2018 Miembro de USF Tampa, Team S17-G3, Boczar Spring 2018
USFT-BOCZAR-S18S17G3
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 1,187
