Saltar al contenido principal
ZTE ZFive G LTE Front-Facing Camera Replacement
Qué necesitas
  1. ZTE ZFive G LTE Front-Facing Camera  Replacement, Front-Facing Camera: paso 1, imagen 1 de 3 ZTE ZFive G LTE Front-Facing Camera  Replacement, Front-Facing Camera: paso 1, imagen 2 de 3 ZTE ZFive G LTE Front-Facing Camera  Replacement, Front-Facing Camera: paso 1, imagen 3 de 3
    • Using the opening tool, pry open the rear cover from the crease at the bottom left corner.
  2. ZTE ZFive G LTE Front-Facing Camera  Replacement: paso 2, imagen 1 de 3 ZTE ZFive G LTE Front-Facing Camera  Replacement: paso 2, imagen 2 de 3 ZTE ZFive G LTE Front-Facing Camera  Replacement: paso 2, imagen 3 de 3
    • Remove the battery with an opening tool or fingernail.
  3. ZTE ZFive G LTE Front-Facing Camera  Replacement: paso 3, imagen 1 de 1
    • Unscrew all 16 screws from the mid-frame J000 screwdriver.
    • Set the screws aside.
  4. ZTE ZFive G LTE Front-Facing Camera  Replacement: paso 4, imagen 1 de 2 ZTE ZFive G LTE Front-Facing Camera  Replacement: paso 4, imagen 2 de 2
    • Gently pull up the device body from the inside.
    • Make sure to pull on all four sides as shown here.
  5. ZTE ZFive G LTE Front-Facing Camera  Replacement: paso 5, imagen 1 de 2 ZTE ZFive G LTE Front-Facing Camera  Replacement: paso 5, imagen 2 de 2
    • Once the body is removed, you will see the front facing camera at the top right corner of the device.
    • Using an opening tool, lift up the protective clip on top of the camera's ribbon wire.
  6. ZTE ZFive G LTE Front-Facing Camera  Replacement: paso 6, imagen 1 de 2 ZTE ZFive G LTE Front-Facing Camera  Replacement: paso 6, imagen 2 de 2
    • Using angled tweezers, gently pull the ribbon wire up from the body.
    • With the ribbon wire out, you should be able to remove the camera.
    • If there is adhesive on the camera backing, it may require more force to pull the camera out.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 342
