Saltar al contenido principal
ZTE ZFive G LTE Back Camera Replacement
Qué necesitas
  1. ZTE ZFive G LTE Back Camera Replacement, Back Camera: paso 1, imagen 1 de 3 ZTE ZFive G LTE Back Camera Replacement, Back Camera: paso 1, imagen 2 de 3 ZTE ZFive G LTE Back Camera Replacement, Back Camera: paso 1, imagen 3 de 3
    • Pry open back cover of the device from the crease at the bottom left corner with an opening tool or fingernail.
  2. ZTE ZFive G LTE Back Camera Replacement: paso 2, imagen 1 de 2 ZTE ZFive G LTE Back Camera Replacement: paso 2, imagen 2 de 2
    • Remove all 16 screws with a J000 screwdriver.
  3. ZTE ZFive G LTE Back Camera Replacement: paso 3, imagen 1 de 3 ZTE ZFive G LTE Back Camera Replacement: paso 3, imagen 2 de 3 ZTE ZFive G LTE Back Camera Replacement: paso 3, imagen 3 de 3
    • Remove the battery with an opening tool or fingernail.
  4. ZTE ZFive G LTE Back Camera Replacement: paso 4, imagen 1 de 3 ZTE ZFive G LTE Back Camera Replacement: paso 4, imagen 2 de 3 ZTE ZFive G LTE Back Camera Replacement: paso 4, imagen 3 de 3
    • Gently pry open the device body by tugging from the inside out, be sure to pull up and away from device.
  5. ZTE ZFive G LTE Back Camera Replacement: paso 5, imagen 1 de 3 ZTE ZFive G LTE Back Camera Replacement: paso 5, imagen 2 de 3 ZTE ZFive G LTE Back Camera Replacement: paso 5, imagen 3 de 3
    • Once body is removed, back-facing camera is placed at the top left corner of device.
    • Using an opening tool, pull up the tab of the camera wire ribbon.
  6. ZTE ZFive G LTE Back Camera Replacement: paso 6, imagen 1 de 3 ZTE ZFive G LTE Back Camera Replacement: paso 6, imagen 2 de 3 ZTE ZFive G LTE Back Camera Replacement: paso 6, imagen 3 de 3
    • Using the blunt-nose tweezers, tug at the camera gently, switching sides to remove adhesive little by little, pull camera out gently.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 6
Todo El Tiempo: 224
