Saltar al contenido principal
ZTE Z667T Speaker Replacement
Qué necesitas
  1. ZTE Z667T Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Gently insert your fingernail into the bottom left crevice of the back cover and lift up.
  2. ZTE Z667T Speaker Replacement: paso 2, imagen 1 de 1
    • Remove the battery by inserting your fingernail at the top of the battery and lift up.
  3. ZTE Z667T Speaker Replacement: paso 3, imagen 1 de 1
    • Using a Phillips #000 screwdriver, remove the five screws located on the back case.
  4. ZTE Z667T Speaker Replacement: paso 4, imagen 1 de 1
    • Gently pry open the back case using the plastic opening tool.
    • Pry open in multiple locations to avoid damage.
  5. ZTE Z667T Speaker Replacement: paso 5, imagen 1 de 1
    • Using the plastic opening tool, gently lift the speaker out of the back case.
Conclusión
Michael Lidbetter
Miembro Desde 02/12/18
121 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 155
