Saltar al contenido principal
ZTE Whirl 2 Speaker Replacement
Qué necesitas
  1. ZTE Whirl 2 Speaker Replacement, Battery: paso 1, imagen 1 de 3 ZTE Whirl 2 Speaker Replacement, Battery: paso 1, imagen 2 de 3 ZTE Whirl 2 Speaker Replacement, Battery: paso 1, imagen 3 de 3
    • Power off your phone before removing the battery.
    • Pry the cover off the back of the phone using your fingers.
  2. ZTE Whirl 2 Speaker Replacement: paso 2, imagen 1 de 3 ZTE Whirl 2 Speaker Replacement: paso 2, imagen 2 de 3 ZTE Whirl 2 Speaker Replacement: paso 2, imagen 3 de 3
    • Pry the battery from the phone using your fingers.
  3. ZTE Whirl 2 Speaker Replacement, Back Panel: paso 3, imagen 1 de 3 ZTE Whirl 2 Speaker Replacement, Back Panel: paso 3, imagen 2 de 3 ZTE Whirl 2 Speaker Replacement, Back Panel: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Remove four 4 mm screws using a Phillips #00 screwdriver.
    • Use a tweezers to remove the lock sticker from the bottom right screw. Remove the 4 mm screw using a Phillips #00 screwdriver.
  4. ZTE Whirl 2 Speaker Replacement: paso 4, imagen 1 de 3 ZTE Whirl 2 Speaker Replacement: paso 4, imagen 2 de 3 ZTE Whirl 2 Speaker Replacement: paso 4, imagen 3 de 3
    • Insert an opening pick between the midframe and the digitizer.
    • Move the pick around the midframe to detach the midframe from the digitizer.
    • The lock button and volume buttons may fall out during this process.
  5. ZTE Whirl 2 Speaker Replacement: paso 5, imagen 1 de 1
    • Remove the midframe from the digitizer.
  6. ZTE Whirl 2 Speaker Replacement, Speaker: paso 6, imagen 1 de 2 ZTE Whirl 2 Speaker Replacement, Speaker: paso 6, imagen 2 de 2
    Comprar
    • Use tweezers to remove the lock button and volume stickers from the phone.
    • The volume buttons peel off much like a sticker.
  7. ZTE Whirl 2 Speaker Replacement: paso 7, imagen 1 de 1
    • Use a tweezers to lift the lock from the ZIF connector above the camera. Pull the ribbon from the connector.
    • The ribbon is connected by a lock. Flip the lock up to unlatch the ribbon with a set of tweezers.
  8. ZTE Whirl 2 Speaker Replacement: paso 8, imagen 1 de 2 ZTE Whirl 2 Speaker Replacement: paso 8, imagen 2 de 2
    • Use a tweezers to lift the lock from the ZIF connector. Pull the ribbon from the connector.
    • Like the camera ribbon, it has a latch that you need to flip to unlock.
  9. ZTE Whirl 2 Speaker Replacement: paso 9, imagen 1 de 1
    • Pull the speaker from the phone by using a pair of tweezers.
    • The speaker has a sticky like back, it peels easiest with a tweezers.
Conclusión
Alana Rucks
Miembro Desde 02/04/20
461 Reputación
4 Guías creadas
Equipo
UW Stout, Team S1-G1, Schneider-Bateman Spring 2020 Miembro de UW Stout, Team S1-G1, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G1
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 81
