Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Use this guide to replace the volume buttons on your ZTE Tempo X.
Partes
No se especificaron partes.
  1. Remove back cover using the divot provided. Remove back cover using the divot provided.
    • Remove back cover using the divot provided.
  2. Find the divot near the bottom of the battery and remove the battery from the device. Find the divot near the bottom of the battery and remove the battery from the device.
    • Find the divot near the bottom of the battery and remove the battery from the device.
  3. Using a Phillips #00 screwdriver, remove the sixteen 3 mm screws holding the back panel in place. Remove the back panel. Remove the back panel.
    • Using a Phillips #00 screwdriver, remove the sixteen 3 mm screws holding the back panel in place.
    • Remove the back panel.
  4. To remove the volume keys, pull them away from the phone. The keys will slide out from their set position. Be aware of the edges of the phone when removing the keys. Be aware of the edges of the phone when removing the keys.
    • To remove the volume keys, pull them away from the phone. The keys will slide out from their set position.
    • Be aware of the edges of the phone when removing the keys.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 107
