Saltar al contenido principal
ZTE Tempo X Front Facing Camera Replacement
Qué necesitas
  1. ZTE Tempo X Front Facing Camera Replacement, Back Cover: paso 1, imagen 1 de 2 ZTE Tempo X Front Facing Camera Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove back cover using the divot provided.
  2. ZTE Tempo X Front Facing Camera Replacement, Battery: paso 2, imagen 1 de 2 ZTE Tempo X Front Facing Camera Replacement, Battery: paso 2, imagen 2 de 2
    • Find the divot near the bottom of the battery and remove the battery from the device.
  3. ZTE Tempo X Front Facing Camera Replacement, Front Facing Camera: paso 3, imagen 1 de 2 ZTE Tempo X Front Facing Camera Replacement, Front Facing Camera: paso 3, imagen 2 de 2
    • Remove the sixteen 3 mm screws on the back cover of the phone using the Phillips #000 screwdriver.
  4. ZTE Tempo X Front Facing Camera Replacement: paso 4, imagen 1 de 3 ZTE Tempo X Front Facing Camera Replacement: paso 4, imagen 2 de 3 ZTE Tempo X Front Facing Camera Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Using the spudger, detach the brown flap by flipping it towards you.
    • With a fine pair of tweezers, pull the front facing camera from the phone.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 167
