Saltar al contenido principal
ZTE Tempo Rear Camera Replacement
Qué necesitas
  1. ZTE Tempo Rear Camera Replacement, Rear Camera: paso 1, imagen 1 de 2 ZTE Tempo Rear Camera Replacement, Rear Camera: paso 1, imagen 2 de 2
    • Pry open the back case to get to the back cover.
    • Remove eight 5mm screws with a PH0 screw.
    • Pry open the back cover with a plastic opening tool.
    • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the back cover.
    • Note: Pry open by finding an edge and forcing it open with the plastic opening tool.
  2. ZTE Tempo Rear Camera Replacement: paso 2, imagen 1 de 2 ZTE Tempo Rear Camera Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the battery ribbon cable.
  3. ZTE Tempo Rear Camera Replacement: paso 3, imagen 1 de 2 ZTE Tempo Rear Camera Replacement: paso 3, imagen 2 de 2
    • Use a plastic opening tool to lift the press-fit connector up and disconnect the rear camera ribbon cable.
    • Lift the rear camera out of the phone.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 160
