Saltar al contenido principal
ZTE Telstra T95 SIM Card Replacement
  1. ZTE Telstra T95 SIM Card Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the back cover using a plastic opening tool. Insert it into each corner starting at the upper left of the back cover and pushing out.
    • You may also use your finger nail if you do not have a plastic opening tool at hand.
  2. ZTE Telstra T95 SIM Card Replacement: paso 2, imagen 1 de 1
    • Using a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
    • The battery snaps out of place and you can remove it using your fingers.
    • When you are ready to insert a battery make sure the three copper teeth on the phone are aligned with the 3 copper dents on the battery.
  3. ZTE Telstra T95 SIM Card Replacement, SIM Card: paso 3, imagen 1 de 1
  4. ZTE Telstra T95 SIM Card Replacement: paso 4, imagen 1 de 1
    • Using your a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
  5. ZTE Telstra T95 SIM Card Replacement: paso 5, imagen 1 de 2 ZTE Telstra T95 SIM Card Replacement: paso 5, imagen 2 de 2
    • Remove the SIM card by placing your index finger over it and sliding it out.
    • When you are ready to re-insert the SIM card make sure the pink side facing up.
Conclusión
2 personas más completaron esta guía.
Jeesenia Rios
Miembro Desde 10/25/14
300 Reputación
2 Guías creadas
Equipo
Gateway, Team 1-1, Johnson Fall 2014 Miembro de Gateway, Team 1-1, Johnson Fall 2014
GCC-JOHNSON-F14S1G1
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 759
