Saltar al contenido principal
ZTE Telstra T95 Headphone Jack Replacement
Qué necesitas
  1. ZTE Telstra T95 Headphone Jack Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the back cover using a plastic opening tool. Insert it into each corner starting at the upper left of the back cover and pushing out.
    • You may also use your finger nail if you do not have a plastic opening tool at hand.
  2. ZTE Telstra T95 Headphone Jack Replacement: paso 2, imagen 1 de 1
    • Using a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
    • The battery snaps out of place and you can remove it using your fingers.
    • When you are ready to insert a battery make sure the three copper teeth on the phone are aligned with the 3 copper dents on the battery.
  3. ZTE Telstra T95 Headphone Jack Replacement, SIM Card: paso 3, imagen 1 de 1
  4. ZTE Telstra T95 Headphone Jack Replacement: paso 4, imagen 1 de 1
    • Using your a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
  5. ZTE Telstra T95 Headphone Jack Replacement: paso 5, imagen 1 de 2 ZTE Telstra T95 Headphone Jack Replacement: paso 5, imagen 2 de 2
    • Remove the SIM card by placing your index finger over it and sliding it out.
    • When you are ready to re-insert the SIM card make sure the pink side facing up.
  6. ZTE Telstra T95 Headphone Jack Replacement, Keypad: paso 6, imagen 1 de 1
    • Unscrew the phone casing using a small screw driver. Remove the four screws on each corner on the back of the phone.
    • Screw sizes are 1.42mm in width and 3.37mm in length.
  7. ZTE Telstra T95 Headphone Jack Replacement: paso 7, imagen 1 de 1
    • Remove front casing by sliding a plastic opening tool between the chrome layer and the top cover.
  8. ZTE Telstra T95 Headphone Jack Replacement: paso 8, imagen 1 de 1
    • The buttons should come off with the front casing but sometimes they don't. If that is the case simply remove them using your fingers and place them with the front cover.
    • If your keypad buttons are sticky you can clean them in this step.
  9. ZTE Telstra T95 Headphone Jack Replacement, Headphone Jack: paso 9, imagen 1 de 1
    • Remove the back casing by taking the motherboard and back casing and pulling them apart.
  10. ZTE Telstra T95 Headphone Jack Replacement: paso 10, imagen 1 de 2 ZTE Telstra T95 Headphone Jack Replacement: paso 10, imagen 2 de 2
    • Using a small phillips #00 screw driver remove the three screws on the clear cover.
    • Screw sizes are 1.15mm in width and 1.51mm in length.
  11. ZTE Telstra T95 Headphone Jack Replacement: paso 11, imagen 1 de 2 ZTE Telstra T95 Headphone Jack Replacement: paso 11, imagen 2 de 2
    • The headphone jack is a square piece at the bottom center of the phone that is sticking out.
    • If it is loose simply remove it.
    • If it is still attached you must remove the headphone jack using the heat pen on your soldering station on top of the headphone jack until it becomes loose.
    • Gently remove the headphone jack using tweezers.
    • At this point you can solder the new headphone jack.
Conclusión
Una persona más ha completado esta guía.
Iris Ortega
Miembro Desde 10/25/14
394 Reputación
2 Guías creadas
Equipo
Gateway, Team 1-1, Johnson Fall 2014 Miembro de Gateway, Team 1-1, Johnson Fall 2014
GCC-JOHNSON-F14S1G1
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 237
