Introducción
In this guide you will be able to replace the front/rear facing camera. Soldering background required.
Qué necesitas
Remove the back cover using a plastic opening tool. Insert it into each corner starting at the upper left of the back cover and pushing out.
Unscrew the phone casing using a small screw driver. Remove the four screws on each corner on the back of the phone.
Remove the back casing by taking the motherboard and back casing and pulling them apart.
