Saltar al contenido principal
ZTE Telstra T95 Battery Replacement
Qué necesitas
  1. ZTE Telstra T95 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the back cover using a plastic opening tool. Insert it into each corner starting at the upper left of the back cover and pushing out.
    • You may also use your finger nail if you do not have a plastic opening tool at hand.
  2. ZTE Telstra T95 Battery Replacement: paso 2, imagen 1 de 1
    • Using a plastic opening tool, push out the battery by inserting it into the small groove at the top left corner of the battery and pushing out.
    • The battery snaps out of place and you can remove it using your fingers.
    • When you are ready to insert a battery make sure the three copper teeth on the phone are aligned with the 3 copper dents on the battery.
Conclusión
Una persona más ha completado esta guía.
Jeesenia Rios
Miembro Desde 10/25/14
300 Reputación
2 Guías creadas
Equipo
Gateway, Team 1-1, Johnson Fall 2014 Miembro de Gateway, Team 1-1, Johnson Fall 2014
GCC-JOHNSON-F14S1G1
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 332
