Saltar al contenido principal
ZTE Speed Earpiece Speaker Replacement
Qué necesitas
  1. ZTE Speed Earpiece Speaker Replacement, Motherboard: paso 1, imagen 1 de 2 ZTE Speed Earpiece Speaker Replacement, Motherboard: paso 1, imagen 2 de 2
    • Pull off back cover at bottom right corner.
  2. ZTE Speed Earpiece Speaker Replacement: paso 2, imagen 1 de 2 ZTE Speed Earpiece Speaker Replacement: paso 2, imagen 2 de 2
    • Remove the seven 3.175mm Phillips head screws from the inner back located at the top, upper-middle-right, middle-right, lower-right, and bottom.
  3. ZTE Speed Earpiece Speaker Replacement: paso 3, imagen 1 de 2 ZTE Speed Earpiece Speaker Replacement: paso 3, imagen 2 de 2
    • With the plastic opening tool the spudger, gently pry off the inner back.
    • Be careful not to pry it off too hard, as it is just a plastic covering.
  4. ZTE Speed Earpiece Speaker Replacement: paso 4, imagen 1 de 1
    • Remove the one 2.381mm Phillips head screw from the motherboard located in the upper-middle part of the phone next to the bottom left corner of the back camera.
  5. ZTE Speed Earpiece Speaker Replacement: paso 5, imagen 1 de 3 ZTE Speed Earpiece Speaker Replacement: paso 5, imagen 2 de 3 ZTE Speed Earpiece Speaker Replacement: paso 5, imagen 3 de 3
    • Using the spudger, gently pry up all ZIF connectors
    • ZIF connectors have a tiny tab that needs to be flipped up in order to safely remove the cable
    • Using same spudger, gently pry up the orange flat top connector
  6. ZTE Speed Earpiece Speaker Replacement: paso 6, imagen 1 de 2 ZTE Speed Earpiece Speaker Replacement: paso 6, imagen 2 de 2
    • Carefully take off motherboard.
  7. ZTE Speed Earpiece Speaker Replacement, Earpiece Speaker: paso 7, imagen 1 de 3 ZTE Speed Earpiece Speaker Replacement, Earpiece Speaker: paso 7, imagen 2 de 3 ZTE Speed Earpiece Speaker Replacement, Earpiece Speaker: paso 7, imagen 3 de 3
    • The earpiece speaker is located at the top-middle of the phone.
    • Using the plastic opening tool, carefully press into side of earpiece speaker and push up.
    • You will then be able to grab the speaker with your figers and remove it.
Conclusión
Una persona más ha completado esta guía.
Garrett Barry
Miembro Desde 03/04/16
722 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 6-3, Bhusal Spring 2016 Miembro de UMass Dartmouth, Team 6-3, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G3
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 396
