Saltar al contenido principal
ZTE Quest n817 Motherboard Replacement
Qué necesitas
  1. ZTE Quest n817 Motherboard Replacement, Battery: paso 1, imagen 1 de 3 ZTE Quest n817 Motherboard Replacement, Battery: paso 1, imagen 2 de 3 ZTE Quest n817 Motherboard Replacement, Battery: paso 1, imagen 3 de 3
    • Ensure that the phone is turned off before starting.
    • Orient the device so that the inset on the right side of the device is facing you.
    • Insert the spudger into the inset and carefully remove the back panel.
  2. ZTE Quest n817 Motherboard Replacement: paso 2, imagen 1 de 2 ZTE Quest n817 Motherboard Replacement: paso 2, imagen 2 de 2
    • Use the ribbon to remove the exposed battery.
  3. ZTE Quest n817 Motherboard Replacement, Motherboard: paso 3, imagen 1 de 1
    • Use the JIS #000 screwdriver to remove the six 3.0mm screws placed in the back of the ZTE Quest.
  4. ZTE Quest n817 Motherboard Replacement: paso 4, imagen 1 de 1
    • Carefully pry open the back panel with the plastic opening tool.
  5. ZTE Quest n817 Motherboard Replacement: paso 5, imagen 1 de 1
    • Use a pair of tweezers to gently disconnect the ribbon cable connector from its socket.
  6. ZTE Quest n817 Motherboard Replacement: paso 6, imagen 1 de 1
    • Pull back the tape encasing the brown ribbon cable connector.
    • Remove the ribbon cable from its socket.
  7. ZTE Quest n817 Motherboard Replacement: paso 7, imagen 1 de 1
    • Unplug the flat-top connector by using a pair of tweezers to pry up each side before removing the connector from its socket.
  8. ZTE Quest n817 Motherboard Replacement: paso 8, imagen 1 de 2 ZTE Quest n817 Motherboard Replacement: paso 8, imagen 2 de 2
    • Disconnect the coaxial connector in the bottom right corner of the motherboard.
Conclusión
Eric Loureiro
Miembro Desde 10/26/18
582 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team S3-G6, Peak Fall 2018 Miembro de UMass Dartmouth, Team S3-G6, Peak Fall 2018
UMASSD-PEAK-F18S3G6
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 488
