Saltar al contenido principal
ZTE Quest n817 Daughterboard Replacement
Qué necesitas
  1. ZTE Quest n817 Daughterboard Replacement, Battery: paso 1, imagen 1 de 3 ZTE Quest n817 Daughterboard Replacement, Battery: paso 1, imagen 2 de 3 ZTE Quest n817 Daughterboard Replacement, Battery: paso 1, imagen 3 de 3
    • Ensure that the phone is turned off before starting.
    • Orient the device so that the inset on the right side of the device is facing you.
    • Insert the spudger into the inset and carefully remove the back panel.
  2. ZTE Quest n817 Daughterboard Replacement: paso 2, imagen 1 de 2 ZTE Quest n817 Daughterboard Replacement: paso 2, imagen 2 de 2
    • Use the ribbon to remove the exposed battery.
  3. ZTE Quest n817 Daughterboard Replacement, Daughterboard: paso 3, imagen 1 de 1
    • Carefully pry open the back panel with the plastic opening tool.
  4. ZTE Quest n817 Daughterboard Replacement: paso 4, imagen 1 de 1
    • Unplug the flat-top connector by lifting each side of the connector up before fully removing it from its socket.
  5. ZTE Quest n817 Daughterboard Replacement: paso 5, imagen 1 de 1
    • Remove the two 2.0mm screws on either side of the daughterboard.
  6. ZTE Quest n817 Daughterboard Replacement: paso 6, imagen 1 de 1
    • Remove the coaxial connector that links the daughterboard to the motherboard.
Conclusión
Eric Loureiro
Miembro Desde 10/26/18
582 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team S3-G6, Peak Fall 2018 Miembro de UMass Dartmouth, Team S3-G6, Peak Fall 2018
UMASSD-PEAK-F18S3G6
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 235
