Saltar al contenido principal
ZTE Maven 2 Midframe Replacement
Qué necesitas
  1. ZTE Maven 2 Midframe Replacement, Back Cover: paso 1, imagen 1 de 3 ZTE Maven 2 Midframe Replacement, Back Cover: paso 1, imagen 2 de 3 ZTE Maven 2 Midframe Replacement, Back Cover: paso 1, imagen 3 de 3
    • Pry off the back cover by inserting an opening tool into the small space on the bottom left between the phone's cover and body.
    • Work your way around the phone with an opening pick to loosen the rest of the back cover.
    • Remove the cover.
  2. ZTE Maven 2 Midframe Replacement, Battery: paso 2, imagen 1 de 1
    • Push in and then up on the bottom of the battery to free it from its compartment.
    • Pull the battery out.
  3. ZTE Maven 2 Midframe Replacement, MicroSD Card: paso 3, imagen 1 de 2 ZTE Maven 2 Midframe Replacement, MicroSD Card: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using your fingers or blunt tweezers, carefully pull the memory card out of the slot.
    • A SIM card is used to demonstrate the process for removing the MicroSD card in these images.
  4. ZTE Maven 2 Midframe Replacement, Midframe: paso 4, imagen 1 de 1
    • Remove the twelve 3 mm screws with a Phillips #00 screwdriver.
  5. ZTE Maven 2 Midframe Replacement: paso 5, imagen 1 de 3 ZTE Maven 2 Midframe Replacement: paso 5, imagen 2 de 3 ZTE Maven 2 Midframe Replacement: paso 5, imagen 3 de 3
    • Wedge the opening tool between the front and side panel to create a gap.
    • Slide the opening pick around the device to detach the midframe.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 170
