Saltar al contenido principal
ZTE Lever Rear Camera Replacement
Qué necesitas
  1. ZTE Lever Rear Camera Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Rear Camera Replacement: paso 2, imagen 1 de 2 ZTE Lever Rear Camera Replacement: paso 2, imagen 2 de 2
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Rear Camera Replacement: paso 3, imagen 1 de 2 ZTE Lever Rear Camera Replacement: paso 3, imagen 2 de 2
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Rear Camera Replacement: paso 4, imagen 1 de 2 ZTE Lever Rear Camera Replacement: paso 4, imagen 2 de 2
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Rear Camera Replacement: paso 5, imagen 1 de 1
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Rear Camera Replacement, Rear Camera: paso 6, imagen 1 de 1
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
  7. ZTE Lever Rear Camera Replacement: paso 7, imagen 1 de 3 ZTE Lever Rear Camera Replacement: paso 7, imagen 2 de 3 ZTE Lever Rear Camera Replacement: paso 7, imagen 3 de 3
    • Remove the top plastic motherboard cover using a plastic opening tool.
  8. ZTE Lever Rear Camera Replacement: paso 8, imagen 1 de 2 ZTE Lever Rear Camera Replacement: paso 8, imagen 2 de 2
    • Using a plastic opening tool, disconnect the camera from the motherboard.
  9. ZTE Lever Rear Camera Replacement: paso 9, imagen 1 de 1
    • Remove the camera from the phone.
Conclusión
Equipo
USF Tampa, Team S5-G2, Passmore Spring 2018 Miembro de USF Tampa, Team S5-G2, Passmore Spring 2018
USFT-PASSMORE-S18S5G2
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 106
