Saltar al contenido principal
ZTE Lever Loud Speaker Replacement
Qué necesitas
  1. ZTE Lever Loud Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Loud Speaker Replacement: paso 2, imagen 1 de 2 ZTE Lever Loud Speaker Replacement: paso 2, imagen 2 de 2
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Loud Speaker Replacement: paso 3, imagen 1 de 2 ZTE Lever Loud Speaker Replacement: paso 3, imagen 2 de 2
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Loud Speaker Replacement: paso 4, imagen 1 de 2 ZTE Lever Loud Speaker Replacement: paso 4, imagen 2 de 2
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Loud Speaker Replacement: paso 5, imagen 1 de 1
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Loud Speaker Replacement, Volume Buttons: paso 6, imagen 1 de 1
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
  7. ZTE Lever Loud Speaker Replacement: paso 7, imagen 1 de 3 ZTE Lever Loud Speaker Replacement: paso 7, imagen 2 de 3 ZTE Lever Loud Speaker Replacement: paso 7, imagen 3 de 3
    • Remove the top plastic motherboard cover using a plastic opening tool.
  8. ZTE Lever Loud Speaker Replacement: paso 8, imagen 1 de 2 ZTE Lever Loud Speaker Replacement: paso 8, imagen 2 de 2
    • Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
  9. ZTE Lever Loud Speaker Replacement: paso 9, imagen 1 de 2 ZTE Lever Loud Speaker Replacement: paso 9, imagen 2 de 2
    • Peel up the volume button cable from the phone with hands, or plastic opening tool.
  10. ZTE Lever Loud Speaker Replacement, Power Button: paso 10, imagen 1 de 1
    • Disconnect the power button from the motherboard with a plastic opening tool.
  11. ZTE Lever Loud Speaker Replacement: paso 11, imagen 1 de 2 ZTE Lever Loud Speaker Replacement: paso 11, imagen 2 de 2
    • Peel the power button cable up from the phone with you hands, or a plastic opening tool.
  12. ZTE Lever Loud Speaker Replacement, Motherboard: paso 12, imagen 1 de 2 ZTE Lever Loud Speaker Replacement, Motherboard: paso 12, imagen 2 de 2
    • Remove the seven 1.6mm Phillips #0 screws from the plastic cover on the bottom of the motherboard.
  13. ZTE Lever Loud Speaker Replacement: paso 13, imagen 1 de 1
    • Remove the bottom plastic motherboard cover with your fingers
  14. ZTE Lever Loud Speaker Replacement: paso 14, imagen 1 de 2 ZTE Lever Loud Speaker Replacement: paso 14, imagen 2 de 2
    • Disconnect the camera from the motherboard with a plastic opening tool.
  15. ZTE Lever Loud Speaker Replacement: paso 15, imagen 1 de 1
    • Disconnect the display cable from the motherboard with a plastic opening tool.
  16. ZTE Lever Loud Speaker Replacement: paso 16, imagen 1 de 3 ZTE Lever Loud Speaker Replacement: paso 16, imagen 2 de 3 ZTE Lever Loud Speaker Replacement: paso 16, imagen 3 de 3
  17. ZTE Lever Loud Speaker Replacement: paso 17, imagen 1 de 1
    • Disconnect the rear speaker cable from the motherboard with a plastic opening tool.
  18. ZTE Lever Loud Speaker Replacement: paso 18, imagen 1 de 1
    • Pry the motherboard cell battery from its position on the case of the phone
  19. ZTE Lever Loud Speaker Replacement: paso 19, imagen 1 de 3 ZTE Lever Loud Speaker Replacement: paso 19, imagen 2 de 3 ZTE Lever Loud Speaker Replacement: paso 19, imagen 3 de 3
    • Using the plastic opening tool, pry the motherboard up, sliding along the edge to separate the pieces.
  20. ZTE Lever Loud Speaker Replacement: paso 20, imagen 1 de 1
    • Remove the motherboard with your fingers.
  21. ZTE Lever Loud Speaker Replacement, Loud Speaker: paso 21, imagen 1 de 2 ZTE Lever Loud Speaker Replacement, Loud Speaker: paso 21, imagen 2 de 2
    • Using the plastic opening tool, remove the speaker.
Conclusión
Luke Kilbourne
Miembro Desde 01/29/18
294 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S5-G2, Passmore Spring 2018 Miembro de USF Tampa, Team S5-G2, Passmore Spring 2018
USFT-PASSMORE-S18S5G2
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 4
Todo El Tiempo: 158
