Saltar al contenido principal
ZTE Jasper LTE Speaker Replacement
Qué necesitas
  1. ZTE Jasper LTE Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • Insert the spudger into the bottom left corner of the phone.
    • Use the spudger to loosen the back cover.
  2. ZTE Jasper LTE Speaker Replacement: paso 2, imagen 1 de 1
    • Insert the black spudger near the bottom left of the battery. There will be an opening to easily to remove the battery.
    • Continuing to use tool, prop up the battery and remove it.
  3. ZTE Jasper LTE Speaker Replacement, Camera: paso 3, imagen 1 de 2 ZTE Jasper LTE Speaker Replacement, Camera: paso 3, imagen 2 de 2
    • Remove nine 0.8mm Phillips #00 screws.
  4. ZTE Jasper LTE Speaker Replacement: paso 4, imagen 1 de 2 ZTE Jasper LTE Speaker Replacement: paso 4, imagen 2 de 2
    • Remove the back cover by pulling upwards.
    • Removing the back cover may take a bit of force.
  5. ZTE Jasper LTE Speaker Replacement: paso 5, imagen 1 de 3 ZTE Jasper LTE Speaker Replacement: paso 5, imagen 2 de 3 ZTE Jasper LTE Speaker Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Disconnect the gold component attached to the camera by pulling upwards using the tweezers.
    • Remove the camera using the tweezers by gripping tightly around the camera and pulling upwards.
    • Camera is attached to the motherboard with adhesive. As such, you may need to use light force to remove the camera.
  6. ZTE Jasper LTE Speaker Replacement, Speaker: paso 6, imagen 1 de 2 ZTE Jasper LTE Speaker Replacement, Speaker: paso 6, imagen 2 de 2
    • Remove the speaker using the tweezers by gripping each side and pulling upwards.
    • Speaker is attached to the back case with adhesive. As such, you may need to use light force to remove the speaker.
Conclusión
Anthony Sou
Miembro Desde 04/22/19
391 Reputación
4 Guías creadas
Equipo
UW Tacoma, Team S1-G1, Cardinal Spring 2019 Miembro de UW Tacoma, Team S1-G1, Cardinal Spring 2019
UWT-CARDINAL-S19S1G1
Miembros de 4
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 130
