Saltar al contenido principal
ZTE Jasper LTE Screen Replacement
Qué necesitas
  1. ZTE Jasper LTE Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Insert the spudger into the bottom left corner of the phone.
    • Use the spudger to loosen the back cover.
  2. ZTE Jasper LTE Screen Replacement: paso 2, imagen 1 de 1
    • Insert the black spudger near the bottom left of the battery. There will be an opening to easily to remove the battery.
    • Continuing to use tool, prop up the battery and remove it.
  3. ZTE Jasper LTE Screen Replacement, Camera: paso 3, imagen 1 de 2 ZTE Jasper LTE Screen Replacement, Camera: paso 3, imagen 2 de 2
    • Remove nine 0.8mm Phillips #00 screws.
  4. ZTE Jasper LTE Screen Replacement: paso 4, imagen 1 de 2 ZTE Jasper LTE Screen Replacement: paso 4, imagen 2 de 2
    • Remove the back cover by pulling upwards.
    • Removing the back cover may take a bit of force.
  5. ZTE Jasper LTE Screen Replacement: paso 5, imagen 1 de 3 ZTE Jasper LTE Screen Replacement: paso 5, imagen 2 de 3 ZTE Jasper LTE Screen Replacement: paso 5, imagen 3 de 3
    • Disconnect the gold component attached to the camera by pulling upwards using the tweezers.
    • Remove the camera using the tweezers by gripping tightly around the camera and pulling upwards.
    • Camera is attached to the motherboard with adhesive. As such, you may need to use light force to remove the camera.
  6. ZTE Jasper LTE Screen Replacement, Screen: paso 6, imagen 1 de 1
    • Disconnect all of these parts from the motherboard.
  7. ZTE Jasper LTE Screen Replacement: paso 7, imagen 1 de 3 ZTE Jasper LTE Screen Replacement: paso 7, imagen 2 de 3 ZTE Jasper LTE Screen Replacement: paso 7, imagen 3 de 3
    • Remove the 0.8mm Phillips #00 screw from the bottom right.
    • Disconnect the gold pin by pulling upwards with the tweezers.
  8. ZTE Jasper LTE Screen Replacement: paso 8, imagen 1 de 3 ZTE Jasper LTE Screen Replacement: paso 8, imagen 2 de 3 ZTE Jasper LTE Screen Replacement: paso 8, imagen 3 de 3
    • Lightly disconnect the power button, volume button and the chip from the motherboard.
    • Be careful not to tear the volume and power button off the motherboard.
  9. ZTE Jasper LTE Screen Replacement: paso 9, imagen 1 de 2 ZTE Jasper LTE Screen Replacement: paso 9, imagen 2 de 2
    • Lightly move clip back to release the motherboard.
    • Gently pull the motherboard away from the screen.
Conclusión
2 personas más completaron esta guía.
Anthony Sou
Miembro Desde 04/22/19
391 Reputación
4 Guías creadas
Equipo
UW Tacoma, Team S1-G1, Cardinal Spring 2019 Miembro de UW Tacoma, Team S1-G1, Cardinal Spring 2019
UWT-CARDINAL-S19S1G1
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 233
