Saltar al contenido principal
ZTE Grand X Max Plus Battery Replacement
Qué necesitas
  1. ZTE Grand X Max Plus Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Make sure you turn off your phone before starting.
    • Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
    • You can also use a hair dryer or a heating gun for this step.
  2. ZTE Grand X Max Plus Battery Replacement: paso 2, imagen 1 de 2 ZTE Grand X Max Plus Battery Replacement: paso 2, imagen 2 de 2
    • After the phone is heated, use the blue plastic opening tool on both sides of the phone.
    • Don't apply too much pressure because the cover can crack easily.
    • To avoid that your cover cracks, you can add tape to back cover.
    • You can use a suction cup to help remove the battery.
  3. ZTE Grand X Max Plus Battery Replacement: paso 3, imagen 1 de 2 ZTE Grand X Max Plus Battery Replacement: paso 3, imagen 2 de 2
    • Carefully remove the cover from the phone.
  4. ZTE Grand X Max Plus Battery Replacement, Battery: paso 4, imagen 1 de 2 ZTE Grand X Max Plus Battery Replacement, Battery: paso 4, imagen 2 de 2
    • Use a plastic opening tool to pry the battery off.
    • The battery will be held down securely by glue, so it'll take quite a bit of sliding underneath to separate it from the compartment.
  5. ZTE Grand X Max Plus Battery Replacement: paso 5, imagen 1 de 3 ZTE Grand X Max Plus Battery Replacement: paso 5, imagen 2 de 3 ZTE Grand X Max Plus Battery Replacement: paso 5, imagen 3 de 3
    • Pull up the piece that is connected to the motherboard. You can pull it using your nails.
  6. ZTE Grand X Max Plus Battery Replacement: paso 6, imagen 1 de 2 ZTE Grand X Max Plus Battery Replacement: paso 6, imagen 2 de 2
    • Remove the battery.
Conclusión
3 personas más completaron esta guía.
Jordano Baer
Miembro Desde 10/02/17
689 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S9-G4, Remmell Fall 2017 Miembro de USF Tampa, Team S9-G4, Remmell Fall 2017
USFT-REMMELL-F17S9G4
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 3,007
