Saltar al contenido principal
ZTE Compel Motherboard Replacement
Qué necesitas
  1. ZTE Compel Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Place the phone on a flat surface with the screen facing down. This will allow easy access to the removable black plastic cover on the back of the phone.
  2. ZTE Compel Motherboard Replacement: paso 2, imagen 1 de 1
    • In the bottom right corner of the device, use your fingernail to remove the back cover of the phone by lifting up and holding the device with your other hand.
  3. ZTE Compel Motherboard Replacement: paso 3, imagen 1 de 1
    • In the top-right area of the battery, use your fingernail to lift the battery out of the phone.
    • If your battery is corroded, take all necessary precautions, such as, gloves and protective eyewear.
  4. ZTE Compel Motherboard Replacement, Camera: paso 4, imagen 1 de 2 ZTE Compel Motherboard Replacement, Camera: paso 4, imagen 2 de 2
    • Remove the 9 screws that measure 4 mm Phillips #000.
    • Use your iFixit Magnetic Project Mat, or any magnetic surface, to hold your removed screws while working on your ZTE Compel.
  5. ZTE Compel Motherboard Replacement: paso 5, imagen 1 de 3 ZTE Compel Motherboard Replacement: paso 5, imagen 2 de 3 ZTE Compel Motherboard Replacement: paso 5, imagen 3 de 3
    • Notice the crease in the shiny black plastic. Insert the flat end of your spudger here, about 3mm above the volume buttons, and work your spudger around the circumference of the phone until the front and back are separated.
  6. ZTE Compel Motherboard Replacement: paso 6, imagen 1 de 2 ZTE Compel Motherboard Replacement: paso 6, imagen 2 de 2
    • Remove the camera by placing your tweezers on the gold piece attached to camera and lift up, disconnecting from the motherboard.
    • Grip the camera with your tweezers and lift up to remove the camera.
    • May need to use light force to remove camera due to the adhesive on the motherboard.
  7. ZTE Compel Motherboard Replacement, Motherboard: paso 7, imagen 1 de 2 ZTE Compel Motherboard Replacement, Motherboard: paso 7, imagen 2 de 2
    • Use your tweezers to remove the black electrical tape covering connectors to the motherboard.
    • Use your tweezers to flip the brown clip up, and pull the ribbon connectors out of the connections.
  8. ZTE Compel Motherboard Replacement: paso 8, imagen 1 de 1
    • Use your tweezers to disconnect the final ribbon connector underneath the motherboard at the top of the phone. The motherboard can now be separated from the LCD Screen.
Conclusión
Kidron Stamper
Miembro Desde 09/06/18
327 Reputación
3 Guías creadas
Equipo
Ohio State, Team S1-G4, Whitney Fall 2018 Miembro de Ohio State, Team S1-G4, Whitney Fall 2018
OSU-WHITNEY-F18S1G4
2 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 233
