Saltar al contenido principal
ZTE Compel Battery Replacement
Qué necesitas
  1. ZTE Compel Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Place the phone on a flat surface with the screen facing down. This will allow easy access to the removable black plastic cover on the back of the phone.
  2. ZTE Compel Battery Replacement: paso 2, imagen 1 de 1
    • In the bottom right corner of the device, use your fingernail to remove the back cover of the phone by lifting up and holding the device with your other hand.
  3. ZTE Compel Battery Replacement: paso 3, imagen 1 de 1
    • In the top-right area of the battery, use your fingernail to lift the battery out of the phone.
    • If your battery is corroded, take all necessary precautions, such as, gloves and protective eyewear.
Conclusión
Kidron Stamper
Miembro Desde 09/06/18
327 Reputación
3 Guías creadas
Equipo
Ohio State, Team S1-G4, Whitney Fall 2018 Miembro de Ohio State, Team S1-G4, Whitney Fall 2018
OSU-WHITNEY-F18S1G4
2 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 6
Todo El Tiempo: 195
