Saltar al contenido principal
ZTE Blade Z Max Fingerprint Sensor Replacement
Qué necesitas
  1. ZTE Blade Z Max Fingerprint Sensor Replacement, SIM Card: paso 1, imagen 1 de 3 ZTE Blade Z Max Fingerprint Sensor Replacement, SIM Card: paso 1, imagen 2 de 3 ZTE Blade Z Max Fingerprint Sensor Replacement, SIM Card: paso 1, imagen 3 de 3
    • Turn the device on it side with the buttons away from you.
    • Using the SIM Card Eject Tool, insert the narrow end into the ejection hole.
    • Press firmly into the hole until the SIM card tray pops out far enough to grab with your fingers.
  2. ZTE Blade Z Max Fingerprint Sensor Replacement: paso 2, imagen 1 de 3 ZTE Blade Z Max Fingerprint Sensor Replacement: paso 2, imagen 2 de 3 ZTE Blade Z Max Fingerprint Sensor Replacement: paso 2, imagen 3 de 3
    • Pull the tray out with your fingers .
    • Remove the SIM card.
  3. ZTE Blade Z Max Fingerprint Sensor Replacement, Fingerprint Sensor: paso 3, imagen 1 de 1
    • Remove the one T2 screw from the side of the phone near where the SIM card tray was.
  4. ZTE Blade Z Max Fingerprint Sensor Replacement: paso 4, imagen 1 de 2 ZTE Blade Z Max Fingerprint Sensor Replacement: paso 4, imagen 2 de 2
    • Insert a plastic opening tool into the space where the SIM card tray used to be.
    • Gently pry the back away form the phone frame until you hear and audible click of the back separating.
  5. ZTE Blade Z Max Fingerprint Sensor Replacement: paso 5, imagen 1 de 2 ZTE Blade Z Max Fingerprint Sensor Replacement: paso 5, imagen 2 de 2
    • Insert the plastic opening tool into the space you created between the phone back and frame.
    • Slide the plastic opening tool along the outside of the phone, underneath the back, to separate the rest of the clips holding the back onto the frame.
  6. ZTE Blade Z Max Fingerprint Sensor Replacement: paso 6, imagen 1 de 2 ZTE Blade Z Max Fingerprint Sensor Replacement: paso 6, imagen 2 de 2
    • Rotate the back over to the side, being careful not to damage the fingerprint sensor ribbon cable.
    • Use a plastic opening tool to separate the fingerprint sensor from the back of the phone.
    • On reassembly, add a piece of simple scotch tape to hold the fingerprint sensor to the phone back.
    • Set the phone back aside.
  7. ZTE Blade Z Max Fingerprint Sensor Replacement: paso 7, imagen 1 de 1
    • Remove the 6 silver 2.9mm screws from the back of the phone with a JIS #000 bit.
    • Remove the 11 black 3.5mm screws with the same JIS #000 bit.
  8. ZTE Blade Z Max Fingerprint Sensor Replacement: paso 8, imagen 1 de 2 ZTE Blade Z Max Fingerprint Sensor Replacement: paso 8, imagen 2 de 2
    • Turn the phone over, with the screen up.
    • Insert the opening tool between the screen and the silver trim that surrounds it.
    • Run the plastic opening tool around the circumference of the phone to separate the clips of that hold the trim to the frame.
  9. ZTE Blade Z Max Fingerprint Sensor Replacement: paso 9, imagen 1 de 2 ZTE Blade Z Max Fingerprint Sensor Replacement: paso 9, imagen 2 de 2
    • Turn the phone back over, with the screen down.
    • Lift the trim piece off of the phone and set aside.
  10. ZTE Blade Z Max Fingerprint Sensor Replacement: paso 10, imagen 1 de 2 ZTE Blade Z Max Fingerprint Sensor Replacement: paso 10, imagen 2 de 2
    • Using a plastic opening tool, separate the fingerprint ribbon connector from the motherboard.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 8
Todo El Tiempo: 816
