Saltar al contenido principal
ZTE Blade Spark Screen Replacement
Qué necesitas
  1. ZTE Blade Spark Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Place phone screen side down on a flat surface.
  2. ZTE Blade Spark Screen Replacement: paso 2, imagen 1 de 2 ZTE Blade Spark Screen Replacement: paso 2, imagen 2 de 2
    • Take an opening tool, and insert it between the phone's backplate and chassis.
    • Work the tool all the way around perimeter of the phone until the backplate is free.
  3. ZTE Blade Spark Screen Replacement: paso 3, imagen 1 de 1
    • Use a Phillips #00 screwdriver to carefully remove all fifteen 3.0 mm screws.
  4. ZTE Blade Spark Screen Replacement: paso 4, imagen 1 de 1
    • Remove the middle plate that was unscrewed from the previous step.
    • At this stage you should have 3 separate parts as shown.
    • For the next step you will be working on the middle part in this picture.
  5. ZTE Blade Spark Screen Replacement: paso 5, imagen 1 de 1
    • Take black covering off of battery.
  6. ZTE Blade Spark Screen Replacement: paso 6, imagen 1 de 2 ZTE Blade Spark Screen Replacement: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Unclip fastener located in the red box. Blunt end tweezers are recommended for this process.
  7. ZTE Blade Spark Screen Replacement: paso 7, imagen 1 de 2 ZTE Blade Spark Screen Replacement: paso 7, imagen 2 de 2
    • Remove battery so you are left with the base of the phone, the battery, and the battery cover separated.
  8. ZTE Blade Spark Screen Replacement: paso 8, imagen 1 de 1
    • Remove the 4mm screws in the 2 red circles shown with the Phillips #00 screwdriver.
  9. ZTE Blade Spark Screen Replacement: paso 9, imagen 1 de 1
    • Heat all 4 sides of the piece with the iOpener to loosen adhesive.
  10. ZTE Blade Spark Screen Replacement: paso 10, imagen 1 de 2 ZTE Blade Spark Screen Replacement: paso 10, imagen 2 de 2
    • Now remove the screen from it's base using the opening tool.
Conclusión
Swap your old screen with your new screen. To reassemble your device with a new screen, follow these instructions in reverse order.
Solomon Barket
Miembro Desde 03/27/23
181 Reputación
1 Guía escrita
Equipo
IUPUI, Team 1-3, Harley Spring 2023 Miembro de IUPUI, Team 1-3, Harley Spring 2023
IUPUI-HARLEY-S23S1G3
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 7
Todo El Tiempo: 112
