Introducción
If your ZTE Axon 7 phone isn't charging and you've tested the battery and the AC adapter, the charging port may need to be replaced.
Axon ZTE 7 is a reliable budget option for a quick and simple phone that needs minimal upkeep. But like most things, they need some tender love and care every now and then. Charger port restoration is a quick and simple repair. To keep the device in peak condition it is recommended that the phone be completely shut off and all accessories unplugged before beginning.
Ensure that you use light pressure whenever removing parts of the device and keep the screws/extra pieces in a neat orderly fashion to make the restoration process easier.
Qué necesitas
Using the SIM Tray Removal Tool, press the pin into the hole on the SIM Tray (located on the top left of the device) to eject the tray.
Herramienta utilizada en este paso:Tweezers$3.99
Use a Phillips #00 screwdriver to remove the 2.0 mm screw securing the bracket at the top of the battery.
Use the angled tweezers to slide the top bracket up and off the phone.
Una persona más ha completado esta guía.
