Saltar al contenido principal
Introducción
The phone battery started to go bad so I decided to replace it.
Partes
No se especificaron partes.
Resumen del Video
    • Insert wisdom here.
Conclusión
9 personas más completaron esta guía.
Dan Dunham
Miembro Desde 15/04/17
3,081 Reputación
26 Guías creadas
4 comentarios
Even tho the video is 2 years old i followed the steps and it went pretty much flawless ( I nicked the plasting surrounding the screen when I pryd it open). My battery was just done and now since the batteryswap it’s finally holding charge again! I dont know what double sided tape to use so I applied 3 dots of glue eachside on parts it doesn’t interfere with anything and now hoping I am done hahaha.
Elroy Brouwer - Contestar
This video saved me from buying a new phone! It took less than an hour to complete. So thanks!
Just an added note. If you use stock or Lineage OS, The kernel may not report the battery levels correctly with the new battery installed. There is a kernel fix for LOS at the following link:
https://forum-xda--developers-com.cdn.am...
Something about the original kernels using a battery id to get the info from.
Heath Delzer - Contestar
I recommend watching this video: it’s a video version of the full process instead of a slideshow: https://www.youtube.com/watch?v=p6wkp3Qc...
A Box - Contestar
Hi I hope someone can advise me on this. I changed the battery of my Axon 7. The red LED lights up and the phone vibrates every 30 seconds while charging. Is this a sign of faulty battery? The seller sent me two and same results. No display is shown on screen while charging. Any idea? thanks.
Handy Manny - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 16
Ultimos 30 días: 97
Todo El Tiempo: 9,769
