Saltar al contenido principal
ZTE Avail 2 Camera Replacement
Qué necesitas
  1. ZTE Avail 2 Camera Replacement, Battery: paso 1, imagen 1 de 3 ZTE Avail 2 Camera Replacement, Battery: paso 1, imagen 2 de 3 ZTE Avail 2 Camera Replacement, Battery: paso 1, imagen 3 de 3
    • Before disassembling your ZTE Avail 2, be sure it is powered off.
    • Remove the back cover using the notch at the bottom of the device.
    • Pull the back cover from the front panel gently to remove it.
  2. ZTE Avail 2 Camera Replacement: paso 2, imagen 1 de 2 ZTE Avail 2 Camera Replacement: paso 2, imagen 2 de 2
    • Remove the battery by the notch in the back plate.
  3. ZTE Avail 2 Camera Replacement, Camera: paso 3, imagen 1 de 1
    • Using your J00 screwdriver, unscrew each of the 8 Philips head screws from the black plate of the device.
  4. ZTE Avail 2 Camera Replacement: paso 4, imagen 1 de 2 ZTE Avail 2 Camera Replacement: paso 4, imagen 2 de 2
    • Using the spudger tool, pull up from underneath the back plate and pop off the piece.
  5. ZTE Avail 2 Camera Replacement: paso 5, imagen 1 de 2 ZTE Avail 2 Camera Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using the tweezers remove the 4 orange ribbon cables. Do this by lifting their corresponding black connectors and pulling the ribbon out.
  6. ZTE Avail 2 Camera Replacement: paso 6, imagen 1 de 1
    • On the left side you will see a cellular antenna cable wire. Remove this wire by gently pulling it off.
  7. ZTE Avail 2 Camera Replacement: paso 7, imagen 1 de 2 ZTE Avail 2 Camera Replacement: paso 7, imagen 2 de 2
    • Lift up the motherboard, this may require some force because it is held on by adhesive.
    • This will allow you to access the camera and the camera mount.
  8. ZTE Avail 2 Camera Replacement: paso 8, imagen 1 de 3 ZTE Avail 2 Camera Replacement: paso 8, imagen 2 de 3 ZTE Avail 2 Camera Replacement: paso 8, imagen 3 de 3
    • Where you can see the front of the camera lightly push on the camera to remove the camera from its holding. The camera will come through the back.
    • Once out of the holding remove the clip holding it to the underside of the motherboard. Now the camera is removed.
    • Once the old camera is removed replace it with the new camera to complete the repair.
Conclusión
5 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 472
