Introducción
This guide is designed to assist in the replacement of the D-Pad for the ZD-N Plus Wireless Controller. Directional pads can be purchased at local electronics stores.
Qué necesitas
Remove the electrical connector attaching each rumble motor to the controller.
Lift up on the circular section of the rumble to remove it from the controller.
Simply remove the plastic piece of the directional pad. It is not glued in so it should come out easily.
