Saltar al contenido principal
ZD-N Plus Wireless Controller Battery Replacement
Qué necesitas
  1. ZD-N Plus Wireless Controller Battery Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove the seven 12mm JIS #00 screws that hold the back panel in place.
  2. ZD-N Plus Wireless Controller Battery Replacement: paso 2, imagen 1 de 2 ZD-N Plus Wireless Controller Battery Replacement: paso 2, imagen 2 de 2
    • Lift up on the back panel of the ZD-N Plus to remove it from the rest of the controller.
  3. ZD-N Plus Wireless Controller Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Use an opening tool to pry the battery from its original position.
    • The battery is glued on, so this may take some effort.
  4. ZD-N Plus Wireless Controller Battery Replacement: paso 4, imagen 1 de 2 ZD-N Plus Wireless Controller Battery Replacement: paso 4, imagen 2 de 2
    • Use an opening tool to pry the connector away from the two metallic prongs.
    • The parts are built to stay together, so this may take some effort.
    • Be careful to not warp the prongs in the process.
  5. ZD-N Plus Wireless Controller Battery Replacement: paso 5, imagen 1 de 2 ZD-N Plus Wireless Controller Battery Replacement: paso 5, imagen 2 de 2
    • Remove the battery from the controller.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 15
Todo El Tiempo: 372
