Saltar al contenido principal
Yuneec Typhoon H Gimbal Bushing Reattachment
Qué necesitas
  1. Yuneec Typhoon H Gimbal Bushing Reattachment, Gimbal Bushing Connectors to Camera Mount: paso 1, imagen 1 de 2 Yuneec Typhoon H Gimbal Bushing Reattachment, Gimbal Bushing Connectors to Camera Mount: paso 1, imagen 2 de 2
    • In order to repair the camera and camera gimbal, remove the camera configuration from the body of the drone.
    • Pull up on the tab connected to the camera configuration and slide the entire apparatus off.
  2. Yuneec Typhoon H Gimbal Bushing Reattachment: paso 2, imagen 1 de 3 Yuneec Typhoon H Gimbal Bushing Reattachment: paso 2, imagen 2 de 3 Yuneec Typhoon H Gimbal Bushing Reattachment: paso 2, imagen 3 de 3
    • Put the gimbal bushings (the rubber balls) back into the plastic alignment mounts.
    • The circle that is separated from the main body of the bushing should then be inserted into the hole.
    • When pushing these bushings back into place, it is smart to use a skinny tool or toothpick.
Conclusión
To reassemble your device, simply slide the camera mount back onto the bottom of the drone.
2 personas más completaron esta guía.
Jake Breul
Miembro Desde 04/16/18
127 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S22-G3, Maness Spring 2018 Miembro de Cal Poly, Team S22-G3, Maness Spring 2018
CPSU-MANESS-S18S22G3
4 Miembros
5 Guías creadas
3 comentarios
Camera not getting power after crash.
Don - Contestar
Crashed drone and camera not getting power anymore. Nothing appears to be broken.
Don - Contestar
Did steps. Bushings ok. Camera still won't communicate.
vickiesamus - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 1,603
