Saltar al contenido principal
Yuneec Breeze 4K Motherboard Replacement
Qué necesitas
  1. Yuneec Breeze 4K Motherboard Replacement, Motherboard M7: paso 1, imagen 1 de 2 Yuneec Breeze 4K Motherboard Replacement, Motherboard M7: paso 1, imagen 2 de 2
    • Before you begin start by putting on a ESD wrist strap to prevent ESD damage and remove the battery.
    • Flip over the drone so that the propellers are facing down and the camera is facing up.
  2. Yuneec Breeze 4K Motherboard Replacement: paso 2, imagen 1 de 3 Yuneec Breeze 4K Motherboard Replacement: paso 2, imagen 2 de 3 Yuneec Breeze 4K Motherboard Replacement: paso 2, imagen 3 de 3
    • Grip the cover that covers the rest of the wires, and give it a slight pull to remove it.
  3. Yuneec Breeze 4K Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove the 4 rubber plugs that hold the drone and its internal parts together.
    • These plugs can be located in each corner of the drone, and are white.
  4. Yuneec Breeze 4K Motherboard Replacement: paso 4, imagen 1 de 1
    • Unplug the four cables that are connected on the top face of the frame.
  5. Yuneec Breeze 4K Motherboard Replacement: paso 5, imagen 1 de 2 Yuneec Breeze 4K Motherboard Replacement: paso 5, imagen 2 de 2
    • The rest of the wires that are still connected can be unplugged.
    • Using a pair of tweezers they can be unplugged.
  6. Yuneec Breeze 4K Motherboard Replacement: paso 6, imagen 1 de 3 Yuneec Breeze 4K Motherboard Replacement: paso 6, imagen 2 de 3 Yuneec Breeze 4K Motherboard Replacement: paso 6, imagen 3 de 3
    • Lift up or tilt entire frame and mother board and unplug all the wires.
  7. Yuneec Breeze 4K Motherboard Replacement: paso 7, imagen 1 de 3 Yuneec Breeze 4K Motherboard Replacement: paso 7, imagen 2 de 3 Yuneec Breeze 4K Motherboard Replacement: paso 7, imagen 3 de 3
    • The battery connector has two wires connected to a plug in with two little screws.
    • Unscrew the two screws and pull it apart using a small tweezers.
  8. Yuneec Breeze 4K Motherboard Replacement: paso 8, imagen 1 de 1
    • Flip over the frame and mother board and unscrew the mother board.
    • There are four screws on each corner of the mother board.
  9. Yuneec Breeze 4K Motherboard Replacement: paso 9, imagen 1 de 2 Yuneec Breeze 4K Motherboard Replacement: paso 9, imagen 2 de 2
    • After the screws are out, the motherboard can be pulled out softly with hands.
    • Remove the motherboard from the device.
Conclusión
5 personas más completaron esta guía.
Ryanne Millis
Miembro Desde 10/04/18
318 Reputación
1 Guía escrita
Equipo
UW Stout, Team S6-G5, Ogden Fall 2018 Miembro de UW Stout, Team S6-G5, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G5
4 Miembros
4 Guías creadas
Un comentario
Excellent step by step instructions.
paul_courville - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 1,932
