Saltar al contenido principal
Yujin Robot iCLEBO Arte Power Transformer Replacement
  1. Yujin Robot iCLEBO Arte Power Transformer Replacement, Power Transformer: paso 1, imagen 1 de 1
    • Unplug transformer before performing operations on it!
    • Press on the two black plastic tabs to remove the rear cover for the charging base.
  2. Yujin Robot iCLEBO Arte Power Transformer Replacement: paso 2, imagen 1 de 1
    • Remove the long cable from inside the base and gently pull the connector from the base.
  3. Yujin Robot iCLEBO Arte Power Transformer Replacement: paso 3, imagen 1 de 1
    • Pull out and remove the old cable from inside the charging base.
    • Detach the thicker part of the cord from the black transformer box.
  4. Yujin Robot iCLEBO Arte Power Transformer Replacement: paso 4, imagen 1 de 1
    • Replace the new thick cable with the old cable just removed. Make sure the cable can fit into the wall before discarding the other cable. If you are residing in the US, this is the connector you need to use.
Conclusión
Trent Bingel
Miembro Desde 02/28/17
428 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S2-G3, Nance Spring 2017 Miembro de USF Tampa, Team S2-G3, Nance Spring 2017
USFT-NANCE-S17S2G3
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 569
