Saltar al contenido principal
Yujin Robot iCLEBO Arte Filter Replacement
  1. Yujin Robot iCLEBO Arte Filter Replacement, Dust Bin: paso 1, imagen 1 de 1
    • Remove the dust bin by gently pressing the silver button on top of the vacuum until the bin releases.
  2. Yujin Robot iCLEBO Arte Filter Replacement: paso 2, imagen 1 de 2 Yujin Robot iCLEBO Arte Filter Replacement: paso 2, imagen 2 de 2
    • Grip the bottom of the dust bin. Push up on the tabs as indicated by the yellow arrows.
    • Empty contents of bin into waste receptacle and rinse with water as needed.
  3. Yujin Robot iCLEBO Arte Filter Replacement, Filter: paso 3, imagen 1 de 1
    • Push the yellow tab releasing the filter harness.
  4. Yujin Robot iCLEBO Arte Filter Replacement: paso 4, imagen 1 de 1
    • Replace or clean filter under a stream of water. When reinserting filter, make sure the filter's cut corner is in the correct corner.
Conclusión
To finish reassembling your device, follow these instructions in reverse order.
Nathan Clark
Miembro Desde 02/28/17
101 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S2-G3, Nance Spring 2017 Miembro de USF Tampa, Team S2-G3, Nance Spring 2017
USFT-NANCE-S17S2G3
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 308
