Saltar al contenido principal
Yujin Robot iCLEBO Arte Dust Bin Replacement
Qué necesitas
  1. Yujin Robot iCLEBO Arte Dust Bin Replacement, Dust Bin: paso 1, imagen 1 de 1
    • Remove the dust bin by gently pressing the silver button on top of the vacuum until the bin releases.
  2. Yujin Robot iCLEBO Arte Dust Bin Replacement: paso 2, imagen 1 de 2 Yujin Robot iCLEBO Arte Dust Bin Replacement: paso 2, imagen 2 de 2
    • Grip the bottom of the dust bin. Push up on the tabs as indicated by the yellow arrows.
    • Empty contents of bin into waste receptacle and rinse with water as needed.
Conclusión
To reassemble the dust bin, follow these instructions in reverse order.
Trent Treiber
Miembro Desde 02/28/17
204 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S2-G3, Nance Spring 2017 Miembro de USF Tampa, Team S2-G3, Nance Spring 2017
USFT-NANCE-S17S2G3
4 Miembros
14 Guías creadas
3 comentarios
My machine says C3 even though the dust bin is successfully in place. Now what? Works fine on hardwood floors.
Amy Abbiatti - Contestar
C3 error even though dustbin is installed correctly. Works fine on hardwood floors. Now what?
I also get C3 error when dustbin is clean and installed correctly - now what?
Philip Melese - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 1,083
