Saltar al contenido principal
Yamaha YPG-225 Keys Replacement
Qué necesitas
  1. Yamaha YPG-225 Keys Replacement, Batteries: paso 1, imagen 1 de 1
    • Turn the keyboard over so that the keys are facing the ground.
  2. Yamaha YPG-225 Keys Replacement: paso 2, imagen 1 de 1
    • Pop the tabs on the battery casing and remove it from the back plate.
  3. Yamaha YPG-225 Keys Replacement: paso 3, imagen 1 de 1
    • Locate the six batteries and remove them from the battery cavity.
  4. Yamaha YPG-225 Keys Replacement, Faceplate: paso 4, imagen 1 de 1
    • Remove the six 10mm screws at the top of the backplate.
  5. Yamaha YPG-225 Keys Replacement: paso 5, imagen 1 de 1
    • Remove the seven 12mm screws in the middle of the back plate.
  6. Yamaha YPG-225 Keys Replacement: paso 6, imagen 1 de 1
    • Remove the eight 10mm screws from the side and the bottom of the back plate.
  7. Yamaha YPG-225 Keys Replacement: paso 7, imagen 1 de 1
    • As the face plate is no longer connected to the body of the keyboard, be careful to not drop the body when performing this step.
    • Flip over the keyboard.
  8. Yamaha YPG-225 Keys Replacement: paso 8, imagen 1 de 2 Yamaha YPG-225 Keys Replacement: paso 8, imagen 2 de 2
    • Lifting from the front and the back of the face plate equally, pull the face plate up and then back, away from the keyboard.
    • Be careful when removing the face plate. There are wires attached.
  9. Yamaha YPG-225 Keys Replacement, Keys: paso 9, imagen 1 de 1
    • Remove the 32mm screws that hold keys down.
    • Depending on which block of keys you wish to remove, there may be four screws instead of three.
  10. Yamaha YPG-225 Keys Replacement: paso 10, imagen 1 de 1
    • Remove the block of keys that holds the key you wish to install.
    • To do this, apply a small force away from the top of the keys and slightly toward the floor.
    • If done correctly, the block of keys will come to a slight downward angle.
  11. Yamaha YPG-225 Keys Replacement: paso 11, imagen 1 de 2 Yamaha YPG-225 Keys Replacement: paso 11, imagen 2 de 2
    • Press the tab on the back side of the block of keys out and detach the black keys.
  12. Yamaha YPG-225 Keys Replacement: paso 12, imagen 1 de 1
    • Remove the individual white key(s) or the black key set(s) that require replacement.
Conclusión
7 personas más completaron esta guía.
Kevin Green
Miembro Desde 09/18/12
308 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 2-62, Propen Fall 2012 Miembro de Cal Poly, Team 2-62, Propen Fall 2012
CPSU-PROPEN-F12S2G62
Miembros de 2
6 Guías creadas
3 comentarios
Excellent, Although I've got a different type of yamaha keyboard, still good inside info.
Diederick Fokker - Contestar
Great article. Thank you so much.
Andreas Devig - Contestar
The instructions were very good and easy to understand. Question on the same subject. How about keys that have popped up on the key bed.
Donald Bryant - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 27
Todo El Tiempo: 21,327
