Saltar al contenido principal
Yamaha YPG-225 Display Replacement
Qué necesitas
  1. Yamaha YPG-225 Display Replacement, Batteries: paso 1, imagen 1 de 1
    • Turn the keyboard over so that the keys are facing the ground.
  2. Yamaha YPG-225 Display Replacement: paso 2, imagen 1 de 1
    • Pop the tabs on the battery casing and remove it from the back plate.
  3. Yamaha YPG-225 Display Replacement: paso 3, imagen 1 de 1
    • Locate the six batteries and remove them from the battery cavity.
  4. Yamaha YPG-225 Display Replacement, Faceplate: paso 4, imagen 1 de 1
    • Remove the six 10mm screws at the top of the backplate.
  5. Yamaha YPG-225 Display Replacement: paso 5, imagen 1 de 1
    • Remove the seven 12mm screws in the middle of the back plate.
  6. Yamaha YPG-225 Display Replacement: paso 6, imagen 1 de 1
    • Remove the eight 10mm screws from the side and the bottom of the back plate.
  7. Yamaha YPG-225 Display Replacement: paso 7, imagen 1 de 1
    • As the face plate is no longer connected to the body of the keyboard, be careful to not drop the body when performing this step.
    • Flip over the keyboard.
  8. Yamaha YPG-225 Display Replacement: paso 8, imagen 1 de 2 Yamaha YPG-225 Display Replacement: paso 8, imagen 2 de 2
    • Lifting from the front and the back of the face plate equally, pull the face plate up and then back, away from the keyboard.
    • Be careful when removing the face plate. There are wires attached.
  9. Yamaha YPG-225 Display Replacement, Main Circuit Board: paso 9, imagen 1 de 1
    • Locate the main circuit board in the middle of the detached face plate.
  10. Yamaha YPG-225 Display Replacement: paso 10, imagen 1 de 2 Yamaha YPG-225 Display Replacement: paso 10, imagen 2 de 2
    • Use a plastic opening tool or spudger to carefully pry up the beige ribbon connectors and remove the wires from them.
    • Be sure to use a tool that is ESD safe!
    • Use a slightly upward force as parallel to the ground as possible.
    • Be sure to make a mental note or jot down the locations of the specific ribbon cables. Some are in close proximity to each other and it can be easy to forget which ribbon goes where.
    • Be sure to unplug the smaller ribbon that connects to a different circuit board.
    • Take care not to use too much force. The connectors are fragile, the ribbon wires are easily bent, and too much force may damage the circuit board if you happen to miss.
  11. Yamaha YPG-225 Display Replacement: paso 11, imagen 1 de 1
    • Move the ribbons out of the way, and remove the eight 10mm screws in the middle that hold the circuit board down.
    • Remove the two 12mm screws in the corner of the circuit board.
  12. Yamaha YPG-225 Display Replacement: paso 12, imagen 1 de 1
    • Remove this wire carefully by hand.
  13. Yamaha YPG-225 Display Replacement: paso 13, imagen 1 de 1
    • Completely remove the circuit board from the face plate.
  14. Yamaha YPG-225 Display Replacement, Display: paso 14, imagen 1 de 1
    • Slide out the screen from its case on the circuit board.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 2-62, Propen Fall 2012 Miembro de Cal Poly, Team 2-62, Propen Fall 2012
CPSU-PROPEN-F12S2G62
2 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 3,835
