Saltar al contenido principal
YORK TM9Y080B12MP11 Furnace Filter Replacement
Qué necesitas
  1. YORK TM9Y080B12MP11 Furnace Filter Replacement, Filter: paso 1, imagen 1 de 1
    • Turn off the furnace by either using the switch near to the furnace or by turning the temperature down with the thermostat.
  2. YORK TM9Y080B12MP11 Furnace Filter Replacement: paso 2, imagen 1 de 2 YORK TM9Y080B12MP11 Furnace Filter Replacement: paso 2, imagen 2 de 2
    • Pull the handhold with force in order to open the 'door' to the filter's location.
    • You will hear a 'pop' and the door should come off easily.
  3. YORK TM9Y080B12MP11 Furnace Filter Replacement: paso 3, imagen 1 de 3 YORK TM9Y080B12MP11 Furnace Filter Replacement: paso 3, imagen 2 de 3 YORK TM9Y080B12MP11 Furnace Filter Replacement: paso 3, imagen 3 de 3
    • Remove the old filter completely by pulling the filter out of its location.
    • On the top of the filter there is an arrow pointing in a specific direction. Make sure you remember that direction.
  4. YORK TM9Y080B12MP11 Furnace Filter Replacement: paso 4, imagen 1 de 2 YORK TM9Y080B12MP11 Furnace Filter Replacement: paso 4, imagen 2 de 2
    • Insert the new filter by sliding it into the same place where the old filter was.
    • Make sure that the arrow on the top of the filter is pointing in the same direction as the old filter was.
    • Make sure that the filter is as far back as it can go.
  5. YORK TM9Y080B12MP11 Furnace Filter Replacement: paso 5, imagen 1 de 2 YORK TM9Y080B12MP11 Furnace Filter Replacement: paso 5, imagen 2 de 2
    • Reattach the door by lining it up with the inside edges of the opening.
    • Use force to make sure that the door is fully secure into its position so that the door does not fall off. You should hear a sound similar to a click once the door is correctly in place.
  6. YORK TM9Y080B12MP11 Furnace Filter Replacement: paso 6, imagen 1 de 1
    • Turn back on the furnace.
    • You can do this by flipping the switch back on or by turning the furnace on with the thermostat.
Linea de Meta
DevBos
Miembro Desde 01/09/24
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 15
Ultimos 30 días: 78
Todo El Tiempo: 163
