Saltar al contenido principal
XtremeMac Luna Dissasembly
Qué necesitas
  1. XtremeMac Luna Dissasembly, Bottom Panel: paso 1, imagen 1 de 3 XtremeMac Luna Dissasembly, Bottom Panel: paso 1, imagen 2 de 3 XtremeMac Luna Dissasembly, Bottom Panel: paso 1, imagen 3 de 3
    • Flip the device over so that the batteries are closest to you.
    • Remove the battery lid by pressing the battery cover's tab and pulling it away from the device.
    • Push the battery against the spring and lift it out of the casing.
    • Repeat with the other battery.
  2. XtremeMac Luna Dissasembly: paso 2, imagen 1 de 1
    • Unscrew all eight 12mm Phillips head screws with a Philips #1 screwdriver.
    • The iFixit 26 bit screwdriver kit will not reach the screws. Make sure to use a screwdriver that is thin enough to not get stuck in the screw holes.
  3. XtremeMac Luna Dissasembly: paso 3, imagen 1 de 2 XtremeMac Luna Dissasembly: paso 3, imagen 2 de 2
    • Flip the Luna back over so that the buttons are facing upward and the LCD screen is facing you.
    • Gently tilt the lid back 45 degrees so that the inside is exposed.
    • Be mindful of the wires inside of the Luna. It is easy to break a connection if a wire gets caught.
Conclusión
Daniel Johnson
Miembro Desde 04/14/13
1 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 3-47, Amido Spring 2013 Miembro de Cal Poly, Team 3-47, Amido Spring 2013
CPSU-AMIDO-S13S3G47
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 424
