Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
If you forgot your Password, PIN, Screen Pattern lock, you can pass the security with your Google account, registered on this phone. You must be in range of WiFi network, used before with this phone.
If you cannot do this, the only way to bypass the security is Hard Reset.
!!! ATTENTION !!! This will erase all your personal information.
Resumen del Video
  1. Open the Emergency call keyboard. Enter this code: *#*#7378423#*#* From the Service Menu select: "Customization Settings".
    • Open the Emergency call keyboard.
    • Enter this code: *#*#7378423#*#*
    • From the Service Menu select: "Customization Settings".
  2. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  3. Select "Reset customization" and "Reset customization and reboot". The Android system will erase all personal information and will reboot the phone to the original factory settings. The Android system will erase all personal information and will reboot the phone to the original factory settings.
    • Select "Reset customization" and "Reset customization and reboot".
    • The Android system will erase all personal information and will reboot the phone to the original factory settings.
  4. Did you do it successfully?
    • Did you do it successfully?
Conclusión
88 personas más completaron esta guía.
ZFix
Miembro Desde 09/12/13
172,114 Reputación
307 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
294 Miembros
937 Guías creadas
I didn't get the Customization Settings option. i just got "Service info", "service settings", and "Service tests"
kennynguyen0829 - Contestar
There is no customization settings option so how do we reset ????
roy7ster - Contestar
Because of high Android version.You have to reflash it with Sony PC Companion:
Factory Reset, Fix Android Problems with Sony PC Companion
Regards.
ZFix -
I did it! Thank you, i was able to unlock it and all my pictures and music are still there! :)
Miri - Contestar
Ahhh great I made it thanks
tkmuparadzi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 63
Ultimos 7 días: 472
Ultimos 30 días: 2,223
Todo El Tiempo: 382,586
