Introducción
If the audio in your recordings is distorted or missing, you may consider replacing the microphone. This guide will show you how to open the Xiaomi Yi and locate the microphone for replacement.
Qué necesitas
Introduce the plastic opening tool into any of the sides of the camera.
Pry with the plastic opening tool at the seam between the front and the back panel.
Remove the four 3.8 mm Phillips #000 screws located in the outer corners of the motherboard.
Locate the solder points connected to the red and black wire on the back of the motherboard.
13 personas más completaron esta guía.
2 comentarios
english version
My camera came with the microphone not soldered at all (two microphone wires were hanging above the motherboard with no sign of soldering).
That was an easy repair as soon as I figured out what's the culprit, but before I've blamed the software for this issue for two days and tinkered with the software for at least 6 hours with no result.
adryjanowski, very nice tutorial, thank you!
