Saltar al contenido principal
Xiaomi Yi Front Panel Replacement
Qué necesitas
  1. Xiaomi Yi Front Panel Replacement, Battery: paso 1, imagen 1 de 2 Xiaomi Yi Front Panel Replacement, Battery: paso 1, imagen 2 de 2
    • Push the battery door switch to the left.
    • Lift the battery door up.
  2. Xiaomi Yi Front Panel Replacement: paso 2, imagen 1 de 3 Xiaomi Yi Front Panel Replacement: paso 2, imagen 2 de 3 Xiaomi Yi Front Panel Replacement: paso 2, imagen 3 de 3
    • Lift the battery tab up.
    • Remove the battery by pulling the removal tab.
  3. Xiaomi Yi Front Panel Replacement, Front Panel: paso 3, imagen 1 de 2 Xiaomi Yi Front Panel Replacement, Front Panel: paso 3, imagen 2 de 2
    • Introduce the plastic opening tool into any of the sides of the camera.
    • Pry with the plastic opening tool at the seam between the front and the back panel.
  4. Xiaomi Yi Front Panel Replacement: paso 4, imagen 1 de 3 Xiaomi Yi Front Panel Replacement: paso 4, imagen 2 de 3 Xiaomi Yi Front Panel Replacement: paso 4, imagen 3 de 3
    • Slide prying tool along the seam until front panel is fully separated from the back panel.
Conclusión
5 personas más completaron esta guía.
Equipo
USF Tampa, Team 15-5, Blackwell Fall 2015 Miembro de USF Tampa, Team 15-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G5
3 Miembros
10 Guías creadas
3 comentarios
Where do you get a spare front panel, the small plastic hooks break easily
ltkipras - Contestar
I would like to know too because i had a crash and i lost the ring that goes around the lens.
fabiocastroam -
For what is the black Strip with the gold plated contact on the front panel? Is that a check for installated front panel, and can i fake them for an replacement panel?
shguro - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 2,874
