Saltar al contenido principal
Xiaomi Redmi Note Headphone Jack Replacement
Qué necesitas
  1. Xiaomi Redmi Note Headphone Jack Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
  2. Xiaomi Redmi Note Headphone Jack Replacement: paso 2, imagen 1 de 2 Xiaomi Redmi Note Headphone Jack Replacement: paso 2, imagen 2 de 2
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
  3. Xiaomi Redmi Note Headphone Jack Replacement: paso 3, imagen 1 de 2 Xiaomi Redmi Note Headphone Jack Replacement: paso 3, imagen 2 de 2
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
  4. Xiaomi Redmi Note Headphone Jack Replacement, Midframe: paso 4, imagen 1 de 2 Xiaomi Redmi Note Headphone Jack Replacement, Midframe: paso 4, imagen 2 de 2
    • Remove twelve 3.5mm Phillips #00 screws from the midframe.
  5. Xiaomi Redmi Note Headphone Jack Replacement: paso 5, imagen 1 de 2 Xiaomi Redmi Note Headphone Jack Replacement: paso 5, imagen 2 de 2
    • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
    • Run the plastic opening tool along the seam.
    • Pry up the midframe with the plastic opening tool.
    • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
    • There will be snapping sounds as the clips on the midframe disconnect from the phone.
  6. Xiaomi Redmi Note Headphone Jack Replacement, Front-Facing Camera: paso 6, imagen 1 de 3 Xiaomi Redmi Note Headphone Jack Replacement, Front-Facing Camera: paso 6, imagen 2 de 3 Xiaomi Redmi Note Headphone Jack Replacement, Front-Facing Camera: paso 6, imagen 3 de 3
    • Use tweezers to lift the retaining flap of the zero insertion force (ZIF) connector to the upright position.
    • Use tweezers to pull the ribbon cable out of the ZIF connector.
    • Remove the front-facing camera from the motherboard.
  7. Xiaomi Redmi Note Headphone Jack Replacement, Rear Camera: paso 7, imagen 1 de 2 Xiaomi Redmi Note Headphone Jack Replacement, Rear Camera: paso 7, imagen 2 de 2
    • Disconnect the rear-facing camera from the motherboard by pulling out the press-fit connector to its left.
  8. Xiaomi Redmi Note Headphone Jack Replacement, Motherboard: paso 8, imagen 1 de 1
    • Locate the three ZIF connectors on the motherboard.
  9. Xiaomi Redmi Note Headphone Jack Replacement: paso 9, imagen 1 de 3 Xiaomi Redmi Note Headphone Jack Replacement: paso 9, imagen 2 de 3 Xiaomi Redmi Note Headphone Jack Replacement: paso 9, imagen 3 de 3
    • Use tweezers to lift the retaining flap on the ZIF connector to the upright position.
    • Pull the ribbon cable out of the connector by pulling to the left.
    • Repeat these steps for the other two ZIF connectors.
  10. Xiaomi Redmi Note Headphone Jack Replacement: paso 10, imagen 1 de 3 Xiaomi Redmi Note Headphone Jack Replacement: paso 10, imagen 2 de 3 Xiaomi Redmi Note Headphone Jack Replacement: paso 10, imagen 3 de 3
    • Locate the antenna cable on the bottom right of the motherboard and use tweezers to lift the cable off of the motherboard.
  11. Xiaomi Redmi Note Headphone Jack Replacement: paso 11, imagen 1 de 2 Xiaomi Redmi Note Headphone Jack Replacement: paso 11, imagen 2 de 2
    • Remove the two 2.9mm Philips #00 screws.
  12. Xiaomi Redmi Note Headphone Jack Replacement: paso 12, imagen 1 de 3 Xiaomi Redmi Note Headphone Jack Replacement: paso 12, imagen 2 de 3 Xiaomi Redmi Note Headphone Jack Replacement: paso 12, imagen 3 de 3
    • Flip over the motherboard to reveal the back.
    • Use a plastic opening tool to pry off the snap fit connector, located on the bottom right off of the motherboard.
  13. Xiaomi Redmi Note Headphone Jack Replacement: paso 13, imagen 1 de 2 Xiaomi Redmi Note Headphone Jack Replacement: paso 13, imagen 2 de 2
    • Lift up the motherboard and turn it over to place it by the side of the phone.
    • Do not attempt to remove the motherboard at this stage. Pulling on the board can damage its connection to the vibrating motor.
  14. Xiaomi Redmi Note Headphone Jack Replacement: paso 14, imagen 1 de 3 Xiaomi Redmi Note Headphone Jack Replacement: paso 14, imagen 2 de 3 Xiaomi Redmi Note Headphone Jack Replacement: paso 14, imagen 3 de 3
    • Use tweezers to peel the vibrating motor off the frame of the phone.
    • The vibrating motor is glued to the frame, so do not be afraid to use force to dislodge it.
  15. Xiaomi Redmi Note Headphone Jack Replacement, Headphone Jack: paso 15, imagen 1 de 2 Xiaomi Redmi Note Headphone Jack Replacement, Headphone Jack: paso 15, imagen 2 de 2
    • Flip over the motherboard and locate the headphone jack at the top left corner.
    • Desolder the 6 soldered connections on the sides of the headphone jack from the motherboard.
    • Learn how to solder and desolder here.
  16. Xiaomi Redmi Note Headphone Jack Replacement: paso 16, imagen 1 de 1
    • Use tweezers to pull off the headphone jack from the motherboard.
Conclusión
7 personas más completaron esta guía.
Zongyi Li
Miembro Desde 04/26/17
1,560 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S22-G4, Livingston Spring 2017 Miembro de Cal Poly, Team S22-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G4
4 Miembros
16 Guías creadas
6 comentarios
You have mentioned it in detailed, but can you mentioned the actual way or sequence of soldering six legs of the jack?
Can you mention the part number of redmi note headphone jack?
link where the jack will be available.
Hemant Kshirsagar - Contestar
I want to buy head phone jack, where the jack will
manu tm manu - Contestar
You can visit iSparehub.com
iSparehub. Com -
Hey, hast du eine Ahnung, wo man eine Kopfhörerbuchse als Ersatzteil für ein Xiaomi Redmi Note 5 Global herbekommt? Das wäre klasse.
Mathias Bork - Contestar
Redmi note 4 earphone jack replacement Ka price Kya hai
Rinku Poonia - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 20
Ultimos 30 días: 73
Todo El Tiempo: 39,089
